Enabling Pre-amp mode on your Network Player activates volume control through its analogue outputs.
This allows you to adjust the volume directly using the front panel dial, remote control, or the StreamMagic app.
Pre-amp mode does not affect audio quality, so the choice depends on how you prefer to manage volume.
- With Pre-amp mode enabled, you can set a suitable volume level on your amplifier and control playback volume via the Network Player.
- With Pre-amp mode disabled, the Network Player outputs a fixed volume, and all volume adjustments must be made through your amplifier.
This flexibility lets you tailor the setup to your preference and system configuration.
