AirPlay 2 from iPhone or iPad
Ensure your player is connected to your network.
Open the app that you want to AirPlay 2 from.
3.
Select
or
4.
Select your player as your AirPlay 2 device.
Note: This product supports AirPlay 2 and requires your mobile device to be running iOS 11.4 or later.
Apple and AirPlay 2 are trademarks of Apple Inc., registered in the U.S. and other countries.
Use of the Works with Apple badge means that an accessory has been designed to work specifically with the technology identified in the badge and has been certified by the developer to meet Apple performance standards.
