1. Make sure the unit is not in Standby mode (indicated by dim power LED)
2. Check that the source component is properly connected
3. Check that your speakers are properly connected
4. Make sure the selected speaker A/B light corresponds to the speaker terminals that the loudspeakers are connected to
5. Make sure the unit is not in mute mode
The mute indicator above the speaker A/B input on the front panel will flash to show that the outputs are muted.
6. Check that the correct analogue or digital input button has been selected on the front panel
There will be no audio from the EXA100 unless the correct input has been selected.
7. Check that the correct balanced or unbalanced input has been selected
Pressing the A1 input selection button will toggle between the balanced and unbalanced inputs. The balanced input is shown by A1 being lit orange, while the unbalanced input is shown by A1 being lit blue.
