POWER OUTPUT - 14 x 50W into 4 Ohms
AMPLIFICATION - Class-D
DRIVERS
14 channels:
4 x 1" silk dome tweeters
4 x 2.25" aluminium cone mid-range
6 x 2.75" long-throw woofers
FREQUENCY RESPONSE - 38Hz to 20kHz +/-3dB
ANALOGUE AUDIO INPUTS - 1 x Line level, 1 x MM phono
DIGITAL AUDIO INPUTS - 1 x TOSLINK optical, 1 x TV eARC
CONNECTIVITY - UPnP, Local USB media, Airplay 2, Google Cast, Internet Radio, Spotify Connect, TIDAL, Qobuz, Deezer, RoonReady.
COMPATIBILITY
Audio Formats: WAV, FLAC, ALAC, AIFF, DSD (DSF and DFF), WMA, MP3 (CBR and VBR), AAC, HE AAC and AAC+ (CBR and VBR), OGG Vorbis
TOSLINK Optical: 16/24bit 32-192kHz PCM only
eARC/ARC: 16/24bit 32-192kHz PCM only
Bluetooth: 5.1 A2DP / AVRCP supporting SBC and AAC
Local USB Media: 1 x USB 2.0 current limited to 1A. PCM up to 32bit/384kHz, DSD up to 128x
UPnP: PCM up to 32bit/384kHz, DSD up to 128x
File Systems: FAT32, NTFS, Ext2/3/4, ExFAT
ETHERNET - IEEE 802.3, 10 Base-T or 100 Base-T
WI-FI - IEEE 802.11 a/b/g/n/ac (2.4GHz / 5GHz)
MAX POWER CONSUMPTION - 300W
STANDBY POWER CONSUMPTION - <0.5W (ECO), <2W (Network Standby)
DIMENSIONS (W x H x D) - 675 x 129 x 290mm (26.6 x 5.1 x 11.4")
WEIGHT - 14.7kg (33lbs)
