You can connect the Evo One to your home wireless network by following the steps below:
1. Ensure the Evo One is in range of your wireless router and then power on the speaker.
Note: If you are setting up your device for the first time or after a factory reset, you will first need to follow the on screen instructions to select your preferred language after powering on your unit.
2. Please download and launch the StreamMagic app and follow the 'Setting up a new product' steps within the app.
3. You will be guided through the wireless setup process within the app, which will explain what to expect to ensure the product is in the correct state for set up.
