24th September 2025
Early update 139-b-001 is now available for Evo One.
- Added support for Qobuz Connect.
4th August 2025
Early update 138-b-013 is now available for Evo One.
- Improved display font style and size for better readability from a distance
- You can now save your EQ setup and easily switch between your custom EQ presets whenever you like
- Fixed an issue on the Now Playing screen on some tablet models.
- Fixed stability issues during product setup on Android 7 devices.
- Fixed an issue where preset images did not always load.
- Fixed an issue where the selected preset was not always highlighted after reopening the EQ section.
6th May 2025
Early update 138-b-003 is now available for Evo One.
- Improved Audio Settings – a smoother and more intuitive interface
- EQ Toggle – option to disable the EQ completely
- Bug Fixes– better performance and stability
20th March 2025
Early Update 138-b-002 is now available for Evo One.
- Add Amazon Music service integration
- Update to TIDAL Connect SDK 1.5.0
- Fixed: Evo One: Occasional noise on right tweeter
- Fixed: Evo One: Multiroom sync issues when adding a new device to a currently playing speaker group
- Fixed: Unit cannot be factory reset when streaming TIDAL Connect
- Fixed: After 3x fast SM App standby button presses the unit becomes unresponsive and eventually crashes and reboots
18th November 2024
Early Update 136-b-017 is now available for Evo One.
- Fix for freeze/crash with some internet radio stations
- Show correct "Listening on" info when using QPlay
5th November 2024
Early Update 136-b-015 is now available for Evo One.
- Added QPlay support
- Fixed: Volume is attenuated when skipping TIDAL and YouTube Music tracks via AirPlay
- Fixed: Recalling UPnP Server (Window Media Player) preset queue tracks but doesn't start playback
- Fixed: AirPlay icon and "Paused" animation are displayed when skipping AirPlay tracks
- Fixed: Cannot playback Minim Server queue preset
- Update SCD/Cast to latest version
- Fixed: Queue didn’t update on queue screen after adding items
- Fixed: Source name was blurry on the front panel display
- Change: VU Meter design change based on initial feedback
- Fixed: Issues turning on from preset after main power cycle
28th October 2024
Early Update 136-b-013 is now available for Evo One.
18th October 2024
Early Update 136-b-012 is now available for Evo One.
- Fixed: Recalling UPnP Server (Window Media Player) preset queues tracks but doesn't start playback
- Fixed: Volume stepping issue
- Fixed: Crashes when selecting 'Play Now' on a folder containing DSD 256 files
