We are aware of this issue that may affect some Android users, where the LEDs still flash white and blue despite being connected.
If this happens, the M100 will still function as expected and this will be solved in a future firmware update.
For now, we would suggest the following:
1. Update to firmware version **2.0.35** or later using the Melomania Connect app
2. Unpair your M100
3. Pair your M100 again
We would also suggest manually disabling LE Audio on your Android device by going to your Bluetooth Settings, selecting the gear icon next to Melomania M100 and ensuring that LE Audio is switched off.
