TIDAL CONNECT
- Open the TIDAL app and choose the playlist, album, song, etc. that you wish to stream to your player.
- Select the Sound Output devices icon within TIDAL and select your player from the list.
- TIDAL Connect should now be streaming your chosen content to your player.
TIDAL VIA STREAM MAGIC
Note: Please ensure that you sign into your TIDAL account when prompted to do so. This will only be required on the first instance of use to link the account to the StreamMagic app.
- Open the StreamMagic app and navigate to the ‘Library’ tab, and then select TIDAL.
- Choose the playlist, album, song, etc. that you wish to stream to your player.
- TIDAL should now be streaming your chosen content to your player.
TIDAL VIA APPLE AIRPLAY OR CHROMECAST
- Select the Sound Output devices icon within TIDAL and select AirPlay or Chromecast from the list.
- Select your player. TIDAL should now be streaming your chosen content to your player via Chromecast or AirPlay.
