Unfortunately, this is not possible as there is no cross-compatibility with other manufacturer's remotes controls and Cambridge Audio units.
Your Network Player can be used with its own remote control (if it comes with one). Sometimes other remotes in the same range will also have some functionality compatibility with their remote, which is generally mentioned in the 'Remote Control' section of the relevant User Manual.
If you're unsure, please do get in touch with our Support team who will be able to advise.
