Try this solution
Secure inputs
Please ensure that the analog or digital inputs are securely connected.
Download and install the Cambridge Audio USB Audio 2.0
Windows-based PCs require a Cambridge Audio USB driver.
Our range of drivers can be downloaded from our Driver Updates page
Ensure that the amplifier is set correctly
Ensure that the amplifier settings are set to receive audio from the entry point to which the DacMagic is connected to.
Check digital input
Please check that the correct digital input is selected (Incoming Sample Rate LED should be on).
