You can assign up to 99 of your favorite Internet Radio stations to presets on your player, which can then be recalled using the StreamMagic app, front panel controls or remote control.
There are two ways to search and store radio stations.
STREAMMAGIC APP
To search and assign a preset:
Within the StreamMagic app navigate to the Radio tab.
Use the Search for Radio search tab at the top of the page or enter a Custom URL link by selecting URL.
Note: Please ensure that the custom URL stream is one of the following supported file types: ALAC, WAV, FLAC, AIFF, DSD (x64), WMA, MP3, AAC, HE AAC, AAC+, and OGG Vorbis.
3.
Once you have located the station you wish to store, select and you will be prompted with the option to Play now or Add to presets.
4.
Add station to the desired preset for your player between 1-99.
5.
You will then receive confirmation that the station is saved to the chosen preset.
TO REMOVE A PRESET ANDROID
Within the StreamMagic app navigate to the Home tab.
Scroll to the bottom of the page where you find your player's Presets, and select EDIT.
3.
To remove the station from the preset, tap the icon and then press Delete.
3.
Tap on the station you wish to remove.
FRONT PANEL CONTROLS
Press the Home button. Using the front panel knob, navigate to Radio.
Search for station either by location, genre or station name.
3.
Once you have located the station you wish to store, select and play.
4.
Whilst station is playing, press the Home button and navigate to Presets > [Set Preset].
5.
Using the front panel knob select your chosen preset. This will then be confirmed on the front panel display.
Note: You may also assign a preset using the remote control, by pressing and holding a number on the remote (1-8) whilst a station is playing. The remaining presets (9-99) can only be accessed via the StreamMagic app.
