If you are unable to connect to your BT100 then please try resetting it using the steps below.
To reset BT100, connect it to a suitable USB port, then press and hold the Cambridge "Ball logo" till the blue LED flashes (hold it down for about 10 sec).
This should complete the reset of the BT100.
