There is no power May 17, 2024 11:37 Updated Try these solutions: Ensure the AC power cord is connected securely Ensure the plug is fully inserted into the wall socket and is switched on Check fuse in the mains plug or adaptor Check the power is on at the front of the unit Related articles AXR wont power up and switch on. How do I perform a factory reset on the AXR85/100? ARX85/100 Manual Can I change the voltage so that my device can be used in another country? Minx X200/X300 Installation Guide & Technical Specifications
