If your AXR will not switch on or power up please try the following steps:
- Disconnect the speakers from the terminals as well as any other sources/devices connected to the unit.
- Disconnect from the mains and leave in a stand-alone, disconnected state for around 30 minutes.
- Connect the power supply only to see if the unit powers on.
- If the unit powers up then you can connect speakers and other sources one at a time.
- If the unit does not power up then please contact us at support where we can provide further options and advice.
Please note that the AXR is rated for 8-ohm speakers.
You can use a pair of 4 or 6-ohm speakers, but we do not recommend using two pairs of 4 or 6-ohm speakers with the AXR as this could result in the amplifier overheating, which in the long run could damage the unit.
