Different Bluetooth devices use different Bluetooth codecs depending on their specifications. If a Bluetooth device is using a higher codec, such as aptX, this requires more data bandwidth compared to SBC (standard BT audio codec), and that can mean they are more susceptible to interference or weak Bluetooth signals, resulting in a shorter Bluetooth range when connected to the EVO's Bluetooth output.
