The ARC function on a TV allows it to send audio and control commands to a connected audio product. This allows the TV to switch on the audio product when needed, and also to control the volume from the TV remote.
TROUBLESHOOTING
No signal shown on the front panel and no audio output from your connected product
- Make sure the HDMI input on your TV supports ARC
- Make sure the TV is set to use a connected audio system rather than its internal speakers
- Make sure that the audio output of your TV is set to 'Stereo PCM (Uncompressed)'
- Make sure your HDMI cable is compatible with HDMI 1.4 or above
- TV will not switch on or control your connected product
- Make sure that 'TV Power Control' is enabled in the StreamMagic app on the ARC source settings page
