You can delete a Custom EQ Preset that you have set in the app by following the steps below:
Under ‘Equaliser’ in the app, select ‘Customise’.
Select ‘Edit’.
Select the ‘X’ icon next to the Custom EQ preset you wish to delete.
The Custom EQ preset is now deleted.
