24th September 2025
Early update 139-b-001 is now available for Evo 75/Evo 150.
- Added support for Qobuz Connect.
4th August 2025
Early update 138-b-013 is now available for Evo 75/Evo 150.
- Improved display font style and size for better readability from a distance
- You can now save your EQ setup and easily switch between your custom EQ presets whenever you like
- Fixed an issue on the Now Playing screen on some tablet models.
- Fixed stability issues during product setup on Android 7 devices.
- Fixed an issue where preset images did not always load.
- Fixed an issue where the selected preset was not always highlighted after reopening the EQ section.
6th May 2025
Early update 138-b-003 is now available for Evo 75 & Evo 150.
- Improved Audio Settings – a smoother and more intuitive interface
- EQ Toggle – option to disable the EQ completely
- Bug Fixes– better performance and stability
20th March 2025
Early Update 138-b-002 is now available for Evo 75/150.
- Add Room compensation feature
- Add 7 band EQ and presets feature
- Add Balance control
- Add Amazon Music service integration
- Update to TIDAL Connect SDK 1.5.0
- Fixed: Evo 75/150: Audio cut-off on first playback from power-on
- Fixed: Unit cannot be factory reset when streaming TIDAL Connect
- Fixed: After 3x fast SM App standby button presses the unit becomes unresponsive and eventually crashes and reboots
18th November 2024
Early Update 136-b-017 is now available for EVO 75 and EVO 150.
- Fix for freeze/crash with some internet radio stations
- Show correct "Listening on" info when using QPlay
5th November 2024
Early Update 136-b-015 is now available for EVO 75/150.
- Added QPlay support
- Fixed: Volume is attenuated when skipping TIDAL and YouTube Music tracks via AirPlay
- Fixed: Recalling UPnP Server (Window Media Player) preset queue tracks but doesn't start playback
- Fixed: AirPlay icon and "Paused" animation are displayed when skipping AirPlay tracks
- Fixed: Cannot playback Minim Server queue preset
- Update SCD/Cast to latest version
- Fixed: Queue didn’t update on queue screen after adding items
- Fixed: Source name was blurry on the front panel display
- Change: VU Meter design change based on initial feedback
- Fixed: Issues turning on from preset after main power cycle
28th October 2024
Early Update 136-b-013 is now available for EVO 75/150.
18th October 2024
Early Update 136-b-012 is now available for EVO 75/150.
30th May 2024
Early Update 134-b-008 is now available for Evo 75/150.
- Avoid random preset 0 appearing
- Change "Chromecast built-in" to "Google Cast" and add dark mode logos
- Fix Control4 device discovery
- Stretch small artwork images
- Swap repeat and shuffle icons order
- Fix potential hang on the Japanese TIDAL Connect prompt
- Improve display layout in various languages
- Add spaces around Spotify/TIDAL URLs to help display layout
- Fix the missing speaker icon
21st May 2024
Early Update 134-b-006 is now available for Evo 75/150.
- Updated user interface
- Added VU meters
- Added time screen
- Added ability to view different now playing screens for each source
- Improved info screen
- Improved software update screen
- Updated Deezer logo
- Updated TIDAL Connect
- Updated Spotify
- Updated Roon
- Updated webmin setting page
- Improved Windows Media Player DLNA playback
- Fixed Media Player metadata missing following power cycles
- Fixed no audio after re-connecting to Spotify
- Improved Chromecast setup in foreign languages
- Fixed Control4 queue management
- Fixed display glitches when playing certain Media Library playlists
- Fixed low sample rate playback on digital inputs
- Improved .WAV file metadata parsing
- Fixed SM App album artwork when playing .M3U playlists
- Added ability to re-order presets
14th February 2024
Early Update 133-b-014 is now available for Evo 75/150.
- No notes
22nd January 2024
Early Update 133-b-010 is now available for Evo 75/150.
- Updated to Cast 2.0
- Updated TIDAL Connect (Hi-Res support)
- Updated Spotify Connect
- Improved front panel display metadata scrolling
- Fixed digital distortion at the start of playback when streaming AIFF via Minimserver
- Fixed the progress bar when Casting the last track in a Youtube Music playlist
- Fixed saving single tracks and mixes as presets from the queue
- Fixed metadata handling when skipping tracks during Cast playback
- Improved auto-power-down behaviour
- Improved Bluetooth status messaging
- Implemented embedded album artwork
- Improved Chinese character metadata handling
- Fixed Cast group playback sync
- Added Korean language support
- Added "Pause" and "Stop" front panel animations
- Improved Bluetooth sender device volume control
2nd August 2023
Early Update 132-b-008 is now available for Evo 75/150.
- Improved front panel metadata handling
13th July 2023
Early Update 132-b-007 is now available for Evo 75/150.
- Improved network connectivity when switching between multiple access points on mesh networks
- Improved playback states when skipping multiple tracks
- Disabled Spotify Normalisation
- Display the Qobuz logo when playing Airable tracks via the media library
- Fixed a crash when selecting UPnP track presets after firmware upgrade
- Show the Bluetooth source device name on the "Now Playing" screen
- Fixed the language select screen when connecting to the network via Ethernet after power-on during setup
- Display multiple artist names on the front panel when playing Spotify via AirPlay
13th April 2023
Early Update 132-b-004 is now available for Evo 75/150.
- Improved digital input sample rate and signal status reporting.
- Fixed a crash when initiating network setup mode via the front panel info screen following a factory reset.
- Fixed low sample rate playback (22kHz) on the digital inputs.
- Added new start-up screen animations.
23rd February 2023
Early Update 131-b-003 is now available for Evo 75/150.
- Fixed ARC no audio output when switching to ARC input via TV power on commands.
- Fixed Webmin "Restart" icon visibility when viewing the Webmin settings page in Dark Mode.
- Fixed French language webmin settings page translations.
- Updated Polish translations.
- Added new translations for various untranslated strings.
- Improved Cast and Roon multi-room playback sync.
28th October 2022
Early Update 130-b-002 is now available for Evo 75/150.
- Updated Spotify
- Improved Deezer metadata handling
- Fixed no audio output after firmware update when Tone Control is enabled
- Fixed occasional Airplay audio anomalies at the start of tracks when skipping through playlists and albums.
22nd August 2022
Early Update 129-b-002 is now available for Evo 75/150
- Audirvana improvements.
12th August 2022
Early Update 128-b-005 is now available for Evo 75/150
- Improved unit behavior when performing a factory reset in network standby mode.
8th June 2022
Early Update 128-b-004 is now available for Evo 75/150
- Improvements for screen issues.
10th May 2022
Early Update 128-b-002 is now available for Evo 75/150
27th April 2022
Early update 128-b-001 is now available for Evo 75/150
23rd March 2022
Early Update 127-b-001 is now available for Evo 75/150
- Fixed Chromecast disconnects
- Updated MQA library
- Fixed lock-up when powering off Evo during splash screen startup
- Fixed previous streaming info briefly displayed on the front panel when entering network standby
- Updated Roon icons.
9th February 2022
Early Update 126-b-001 is now available for Evo 75/150
- Updated Spotify
- Fixed crash when using Roon DSP sample rate conversion
- Fixed AirPlay disconnects
- Fixed AirPlay sample rate/bit depth not being displayed
- Display the name of the sending device on the AirPlay source
- Fixed long delay before playing Antenne Bayern stations
- Fixed crash when playing RNE classical radio station
- Fixed info screen fields for Network & Internet not updating when language changes
- Added Italian translation for "Media Library"
16th December 2021
Early Update 125-b-001 is now available for Evo 75/150
- Added exFAT USB drive support
- Updated AirPlay
- Improved Russian and Polish front panel info display page
- Improved front panel info display page spacing
- Fixed volume level returns to 1 after Eco mode power cycle
- Fixed distortion when attempting to play unsupported native DSD512 steams via USB Audio
- Fixed volume levels when enabling unsupported Tone Control during DSD (DoP) playback
- Fixed Left/Right output swapped when playing DSD files
- Fixed a loud pop when switching from a home theatre bypass-enabled analogue input to a non-home theatre bypass-enabled analog input with an active signal.
13th October 2021
Early update 124-d-005 is now available for Evo 75/100
- Fixed a unit crash when adding tracks to the queue
- Fixed broken PBB internet radio streams
- Fixed reconnecting to the network when Wi-Fi signal is lost temporarily
- Fixed a short burst of sound when entering Eco mode standby while listening to physical inputs
- Updated Japanese translations
- Fixed info screen translations
- Updated patch to improve UI crash
- Updated the info screen to return to the current source after one minute of inactivity
- Updated Cast
16th September 2021
Early update 124-c-001 is now available for Evo 75/100
- Updated Cast
- Fixed low sample rate internet radio playback
- Fixed WMA file meta-data parsing
- Fixed entering Network Standby during Bubble UPnP queue playback
- Fixed mute state after switching between speaker and wired headphone outputs
- Patch to improve UI crash.
12th August 2021
Early Update 124-b-001 is now available for Evo 75/150
- Fixed start of track cut-off when starting Spotify playback from Network Standby.
- Fixed adjusting the display brightness when the unit is in Network Standby mode.
- Fixed audio issues when playing low sample rate streams via digital inputs.
- Fixed a crash when quickly skipping through tracks in the queue using the IR remote control.
- Fixed distortion when using both Tone Control and Input Trim at the same time on analog inputs.
- Fixed incorrect DSD format metadata reporting on some hardware revisions.
5th July 2021
Early Update 124-a-078 is now available for Evo 75/150
- Fixed info screen translations.
- Updated description for "Moving Magnet Phono"
- Updated USB Audio descriptions and translations
- Updated to TIDAL Connect SDK 1.1.9.13.
- Restart the whole UI if rebooted while on network standby (fix corrupted screen).
- Fixed crashes during prolonged Qobuz playback via Cast.
17th June 2021
Early update 124-a-037 is now available for Evo 75/150
- Various crash fixes
- Improved Tone Control response on analog inputs
- Updated the Cambridge Audio logo on the Webmin settings page
- Improved mute/un-mute
- Fixed low-resolution radio station playback.
- Prevent the volume level from being displayed when powering on from network standby.
27th May 2021
Early Update 124-a-018 is now available for Evo 75/150
- Added Tone Control.
- Updated network status icons
- Improved network setup mode via the front panel
- Fixed IR remote control functions when Bluetooth output is selected
- Fixed brief audio drop-outs when re-selecting the current Bluetooth output
- Improved progress bar reporting when skipping tracks
- Fixed Bluetooth volume problem if set to 0 before pairing
- Increased maximum number of presets from 20 to 99
- Fixed metadata reporting for Control4/RTI systems
- Fixed volume level discrepancies when setting the volume via the StreamMagic App, front panel or TV ARC control
- Fix to prevent the unit from powering off if the remote control power button is held during power-on from ECO Mode standby
