POWER OUTPUT
150W into 8 Ohms
AMPLIFICATION
Class-D
DAC
ESS Sabre ES9018K2M
FREQUENCY RESPONSE
20Hz –20kHz +/-3dB
ANALOGUE AUDIO INPUTS
1 x RCA, 1 x Balanced XLR, 1 x MM Phono
DIGITAL AUDIO INPUTS
2 x TOSLINK optical, 1 x S/PDIF coaxial, Bluetooth (integrated), 1 x TV ARC, USB Audio
USB Audio: USB Type B conforming to USB Audio Class 1 or USB Audio Class 2 (user selectable)
Bluetooth: 4.2 A2DP/AVRCP supporting SBC, aptX and aptX HD codecs
COMPATIBILITY
TOSLINK optical: 16/24bit 44.1-96kHz PCM only
S/PDIF coaxial: 16/24bit 44.1-192kHz PCM only
ARC: 16/24bit 44.1-192kHz PCM only
USB Audio Class 1: Up to 24-bit 96kHz (asynchronous)
USB Audio Class 2: Up to 32-bit 384kHz (asynchronous) and up to DSD-256
UPnP, Local USB media, Airplay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL, Qobuz, Amazon Music, RoonReady.
Note: USB media maximum current 1A
AUDIO FORMATS
ALAC, WAV, FLAC, AIFF, DSD (x256), WMA, MP3, AAC, HE AAC AAC+, OGG Vorbis
OUTPUTS
Speakers A+B, 3.5mm headphone, Preamp Output, Subwoofer Output, Bluetooth (integrated)
Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD
ETHERNET
WI-FI
Dual-Band 2.4/5GHz
MAX POWER CONSUMPTION
700W
STANDBY POWER CONSUMPTION
<0.5W
DIMENSIONS (W x H x D)
317 x 89 x 352 mm
WEIGHT
5.3Kg
