IOS
Ensure that your EVO is in range of your wireless router, and then power on your unit.
Go to the Wi-Fi settings on your iOS device and under ‘SETUP NEW AIRPLAY SPEAKER’ select 'EVO 75 or EVO 150'.
3.
Once connected, to complete unit setup download and install the StreamMagic app from the Apple App Store.
ANDROID
Download and install the StreamMagic app from the Google Play store.
3.
Open the StreamMagic app and select ‘Connect’.
4.
Under Choose a device select 'Set up a new device' and then select the EVO 75 or 150.
5.
Select ‘Wireless Connection’ and then 'Continue'.
6.
Your Android device will now show all available Wi-Fi devices in range. Select 'Setup: EVO 75 or EVO 150'.
7.
Once connected, you will be prompted to enter your Wi-Fi network password. Enter the
password and select 'Continue'.
8.
Your EVO will now connect to your Wi-Fi network, this may take up to a minute.
9.
Once connected, complete the initial setup of your unit within the StreamMagic app.
Note: Your EVO will need to be in the range of your wireless router.
Important Note: It is vitally important that your EVO remains connected to a Wi-Fi network as often as possible. This will ensure that the unit is regularly updated to meet essential security protocols, third-party compatibility, and the latest software requirements.
Failure to maintain your device with regular firmware updates as provided by Cambridge Audio will void the product warranty and is likely to cause major issues to the unit in time. Please ensure that your unit is updated to the most current firmware version. Information on the latest firmware version for the EVO can be found here.
Note: Where possible, avoid the use of powerline adapters, or Wi-Fi signal boosters/extenders as these can disrupt the reliability of the network connection.
