EVO 75
The EVO 75 doesn't feature a dedicated Phono input.
Some modern turntables come with a built-in Phono Pre-amp stage. With this enabled you can connect your turntable directly to the analogue RCA input on the EVO.
If your turntable doesn't have its own built-in Phono Pre-amp stage, a separate Phono Pre-amp will be required, which can then be connected to the analogue RCA input on the EVO.
With either connection, you will need to then ensure that the 'Aux' source has been selected on the EVO.
EVO 150
As the EVO 150 has its own MM Phono input, you can connect a turntable with an MM cartridge directly to this input.
If your turntable has its own built-in Phono Pre-amp stage, you will either need to disable this before connecting it to the MM Phono input, or keep it enabled and connect it directly to the analogue RCA input on the EVO. (You will be utilising your turntable's Phono Stage with the latter connection.)
You will then need to select the 'Aux' or 'MM' source on the EVO depending on your connection.
