There are 3 means of controlling the Air: The Cambridge Audio Air app, Bluetooth or AirPlay.
If you are using an Android or Apple device, you can download and install the Cambridge Audio Air app from your app store for free. This will then allow you to setup your Air speaker as well as access up to 20,000 Internet Radio stations and save them as presets for easy access in the future.
Please Note: Android smartphones/tablets must be running Android version 4.0 or later to run the Air app.
Bluetooth
You can connect almost any Bluetooth transmitting device to the Air. This includes but is not limited to Smart Phones, Laptops/ PCs and MP3 players. Please see the Quick Start Guide for the steps to pair these.
AirPlay
If you own an Apple device or an AirPlay app, you can also connect to the Air via your WiFi network. Compatible products for this connection include iPods, iPads, iPhones and iTunes within a Mac or Windows.
