If your router supports WPS(WiFi Protected Setup), then you can connect the Air to your network using this method.
To connect using WPS, please follow the steps below.
- Press the WPS button on your router (please consult router instructions for details).
- Then press the WPS button once on the rear panel of the Air.
- The WPS light on the rear panel will flash Orange > Green > Red for up to 2 minutes until the Air has automatically connected to your network.
- Once the unit has successfully connected to the network, this will be indicated when the WPS light becomes solid Green.
