To perform a factory reset on the Air, please follow the below steps.
- Press and hold the Power button(on top of the unit) and the WPS button(on the rear panel) together for 10-15 seconds.
- Once the LED above the WPS button turns amber, please release both buttons and turn the Air back on.
Please note: Carrying out a factory reset will erase any stored presets, preferences and network connection details, all of which will need to be re-entered once your Air has restarted.
