Skip to main content
What do the colours of the Air's WPS light Indicate?
- Solid Green - network is connected
- Flashing Green (fast) - system is booting
- Flashing Green (slow) - connecting to a network
- Flashing Green, Amber, Red - in WPS connect mode. Once the WPS mode is activated it will search for another device for approximately two minutes
- Flashing Green, Amber - in Minx WiFi Connect mode
- Flashing Amber (slow) - indicates that there is a problem with the network. Check that the router is switched on and not out of range
