The serial numbers for most Cambridge Audio Hi-Fi products can be found on the rear of the unit, above the barcode. All recent Hi-Fi products will have the serial number written in the following format; XX X12345 1234 1234, and should be inputted as such when completing support forms or RMA requests.
Note: If you are unsure or can not find the serial number for your device, please enter a generic serial number such as XX X12345 1234 1234.
The serial number of your Melomania product is located on the bottom of the product box above the barcode. It is a 16-digit code which begins with the letters VM, AK, FJ, or HA
For example, VM C11163 7060 0000.
The serial number for your Melomania M100 is a 16-digit number beginning with 'HA' and can be found on the bottom of the charging case and, alternatively, on the bottom of the product box.
The serial number for Melomania P100 is a 16-digit number beginning in 'FJ' and can be found on the product box. It can also be found on the right ear cup by removing the ear cushion on this side.
The serial number for the Melomania 1 and 1+ can also be located on the inside of the charging case lid.
It is a 16-digit code which begins with the letters AK.
For example, AK C12345 1234 1234.
The serial number should be inputted in this format when completing support forms or RMA requests.
Note: If you are unsure or can not find the serial number for your device, please enter a generic serial number, such as AK C12345 1234 1234.
