To enable Early Updates, and try out the latest software ahead of the general release please navigate to the Settings page of the StreamMagic app. Settings > Early Updates > On > Done.
Once you have subscribed to Early updates, your unit should prompt you for a firmware update if one is available.
To revert back to the General release software, just reverse the process Settings > Early Updates > Off> Done.
