29th October 2025
General release 022-a-152 is now available.
- Fixed an issue with 24-bit Spotify Lossless support.
6th June 2024
General release 022-a-151 is now available.
- Fixed APD behaviour during BT100 playback
- Added ability to re-order presets
24th April 2024
General release 022-a-147 is now available.
- Added TIDAL Connect Hi-Res support
- Updated Spotify Connect
- Updated AirPlay
- Added ability to save currently playing tracks as a preset
- Added ability to save the queue as a preset
- Added description metadata for Media Library services
- Disabled Spotify loudness normalisation
- Improved Auto-Power-Down behaviour
- Improved metadata handling when skipping tracks during Cast playback
- Updated StreamMagic icons on front panel prompt screens
- Disable backlight during updates and factory resets in standby
- Improved Bluetooth prompt screens
- Improved WAV metadata parsing
- Improved playback states when skipping tracks
- Updated translations
20th January 2023
022-a-132
- Fixed a crash when browsing the Media Library via the front panel
Please note:
Please make sure you have updated to the latest version of the StreamMagic app:
iOS App: 2.10.0
Android App: 2.10.1
18th January 2023
022-a-131
- Added Deezer support via the Airable service
- Updated TIDAL and Qobuz integrations for support via the Airable service
- Fixed an issue with Qobuz playlists
- Updated Spotify
- Fixed a crash when starting Audirvana playback
- Updated Italian language translations
Known issues:
- Some translations are missing or incomplete
- Some translations feature symbols instead of letters
- Track resolution is missing from Qobuz
- Deezer symbol is displayed when listening to Qobuz
We are working on a fix for all of these known issues as a priority and will release an update to address them as soon as we can. We apologize for any inconvenience caused.
Please note:
Please make sure you have also updated to the latest version of the StreamMagic app version 2.10.0 in order to take advantage of some of these features.
If you have saved any TIDAL or Qobuz presets within the StreamMagic app you may need to save these again after updating.
30th March 2022
022-a-123
- Added Media Player presets.
- Updated Spotify Connect.
- Updated TIDAL Connect.
- Updated AirPlay.
- Improved AirPlay multi-room sync.
- Fixed AirPlay sample rate/bit depth not being displayed.
- Fixed a crash when playing RNE classical radio station.
- Fixed (SR) Swedish Radio audio dropouts.
- Fixed balance control settings after a network standby power cycle.
- Added fixes to support the mini-player in the Android SM App.
9th November 2021
022-a-103
- Added Home Theater Bypass for Edge NQ
- Fixed a unit crash when adding tracks to the queue
- Fixed broken PBB internet radio streams
- Fixed entering Network Standby during Bubble UPnP queue playback
- Fixed adjusting the display brightness when in Network Standby.
1st September 2021
022-a-093
- Fixed Spotify long album name metadata scrolling on the front panel display.
- Fixed a crash when quickly skipping through tracks in the queue using the IR remote control.
- Fixed album art not displaying from a USB drive when the streamer is offline.
- Fixed Cambridge Connect transport controls on CXR.
1st July 2021
022-a-083
- Fixed a TIDAL Integrated audio dropout when skipping AAC tracks with a premium subscription
- Fixed a Cast authentication issue that caused Cast to stop working for some users
- Changed "play-from-here" behavior to clear the current queue before adding new tracks
- Fixed playback pausing between tracks when using 3rd party UPnP control points.
- Fixed CXR power on/off via the SM App
- Fixed CXR IR remote control transport buttons
- Increased maximum number of presets from 20 to 99
- Fixed metadata reporting for Control4/RTI systems
- Removed the 50th anniversary Cambridge Audio logo from the Webmin settings page
- Improved initial setup process
- Updated "Edge Remote" app references to "StreamMagic"
- Updated Webmin device settings headings
- Fixed playback when selecting specific tracks from the queue on CXR
- Fixed mDNS broadcasting after changing the device name and then rebooting
26th April 2021
v022-a-064
- Improved TIDAL Connect stability.
- Fixed occasional pops and clicks at the end of some DSD tracks.
- Fixed German translation for "Skip" which prevented users from completing setup.
- Fixed playback of invalid or corrupted .dsf files.
NB: Please be aware that once updated your device will no longer support browsing TIDAL from the front panel Library of the device or from the Cambridge Connect app.
This is because accessing Tidal via the front panel and through the Cambridge Connect app uses an older method of log-in that Tidal is phasing out for security reasons. In order to be able to make use of the functionality of Tidal Connect we have therefore had to remove access via these methods at Tidal's request. The more modern log-in method in the StreamMagic app is much more secure.
We do apologize for any inconvenience that this may cause.
22nd March 2021
v022-a-043
- Added TIDAL Connect.
- Fixed various broken Internet Radio streams.
- Improved Webmin translations.
30th June 2020
v018-a-078
CXNv1
- No changes.
9th April 2020
v018-a-075
CXNv1
- Fixed DSD sample rate reporting when playing DSD files over digital inputs.
- Improved USB drive detection with the StreamMagic app
28th February 2020
v018-a-062
Features:
- Added a QR code banner to direct users to the StreamMagic app download page.
- Added source description fields to the sources settings page.
- Added dark mode to the settings page for iOS devices.
Improvements:
- Fixed WAV + AIFF + DFF/DSD files played from USB drives from reporting 00:00 track length.
- Removed [All Stations] filter from Radio Genres search to reduce load times.
- Removed a 32-character limit when entering TIDAL username and password login details from the front panel.
- Updated translations.
- Fixed audio playback when coming out of Network standby with a queue action.
9th December 2019
v017-a-070
Features:
- Add support for Spotify Free.
- Add repeat track (repeat-1) functionality to Spotify Connect.
Improvements:
- Improved Spotify preset handling.
- Fixed AirPlay audio glitch when switching between AAC tracks.
- Various webmin updates.
- Fixed CBUS power-on commands when the unit starts up in ECO mode.
- Fixed MCU Error messages appearing when upgrading some units.
- Added translations for "ECO mode" in Dutch and Polish.
- Added new StreamMagic splash-screen to unit start-up.
- Replaced old Cambridge Connect app icons with new StreamMagic app icons.
9th May 2019
v014-a-140
Improvements:
- Fix the end of some tracks being cut off.
- Improved playback on low-bit-rate MP3 files over UPnP.
- Fix for removing pre-sets via Webmin.
- Fix to prevent Alva TT+BT100 from getting stuck in a stopped state.
22nd January 2019
v014-a-109
Improvements:
- Fix some USB drives not being detected.
- Fix a rare crash when setting the language and then immediately changing preamp mode.
- Fix to stop adding previously deleted queue items to the queue after changing the shuffle state.
- Fix to ensure that the next track is played after deleting the current track in the queue.
- Fix Apple Wireless Accessory Configuration for users connecting to hidden networks.
- Fix to remove track length restrictions on High-resolution WAV files larger than 2GB.
20th November 2018
v014-a-089
Improvements:
- Fix for APEv2 support.
- Fix for the front panel still illuminated when the unit is put on standby by the remote app.
- Fixed crash when going to network standby while the USB drive is mounting.
- Improved Audirvana support - better synchronization with the Mac app.
24th September 2018
v014-a-081
New Features:
- Added option to remove TIDAL from Library
Improvements:
- Fixed issue with CXN,851N, and SM6v2 pausing at the end of a track with some UPnP control points
- Fixed issue with playlists appearing in incorrect order
- Fixed issue with ‘Play from here’ on USB drive
- Translation updates
3 April 2018
v012-a-471
Features:
- TIDAL Support
- DASH/HLS support including FLAC streams
- Support for higher-bitrate BBC stations in the UK as well as on-demand content
- WMA Pro/Lossless Support
- Seek support in Spotify/media playback (currently only available via front panel and remote)
- Spotify Podcast support
- Removal of Spotify 100 track limit
- Improved Spotify preset functionality
- New Webmin design
- Streaming volume limit (set to 100% by default)
- Presets now stored on devices instead of external servers
- Presets now reset with Factory Reset
- Inputs can now be set as presets
- Allow preset selection/buttons to power on from the network standby
- Automatic overnight firmware updates
- Screen protection for physical inputs (not on streaming or radio sources). The screen switches off after 30mins of inactivity
- 50th-anniversary boot splash screens
Fixes:
- Performance improvements
- Detect and fix incomplete factory resets
- Fix duplicate information when browsing some UPnP servers
- Fix spurious busy spinner on Settings/Auto Power Down screen
- Handle UTF-8 characters when fast-scrolling through menus
- Display prompt screen correctly when switching from media player to IR (no saved station)
- Allow change of language without restarting
- Other Minor Bug fixes
