1. Check that the batteries have not expired
2. Ensure that nothing is blocking the remote sensor
3. Ensure that you are not attempting to control the AXC with the ‘AXA35 Only’ functions on the remote.
4. The following controls on the remote are to operate the AXA35 unit only.
10. VOLUME - Increases or decreases the volume of the unit. Also used to change the bass, treble and balance settings when these are selected.
11. MENU - Toggles between Bass, Treble and Balance options. Use the volume buttons to change the level of the selected option.
12. SOURCE BUTTONS (CD, BD/DVD, MP3/AUX, TUNER, PHONO) - Press the relevant button to select the desired music source.
13. MUTE – Mutes the output of an AXA35.
Note: These controls work on the AXA35 only and are not compatible with Cambridge Audio Azur amplifiers/receivers or units from other manufacturers
