1. Check the disc is not loaded upside down
2. Check that the disc is not too scratched or dirty
3. Check that the disc type is compatible with the AXC25/35
The AXC25/35 has been designed to only play:
- Compact discs
- Recordable CDs (CD-R)
- Re-writable CDs (CD-RW) bearing the identification logo.
Note: The CD-R/CD-RW discs should contain properly recorded TOC (Table of Contents) information so that they can be played back.
The AXC25/35 can only play the discs recorded in the CDDA format designed for music reproduction or those containing MP3 or WMA files. Do not attempt to play a disc on this unit containing other data, such as a data CD-ROM for PCs.
4. Make sure that the interconnects are inserted correctly
Please check for any loose, damaged, or otherwise unsecured cables.
5. Ensure that the amplifier is set correctly
Check that the amplifier is set to the correct input, and is actively outputting to the speakers.
