You may connect a USB SSD, USB HDD or flash drive to the CXN (V2) via the USB Media inputs located on the front and rear of the unit for playback. Once connected the following formats are supported: ALAC, WAV, FLAC, AIFF, DSF and DFF containing DSD64 at 2.8224 MHz or DSD128 at 5.6448 MHz, WMA, MP3, AAC, HE AAC, AAC+ and OGG Vorbis.
Note: The EDGE NQ will read large capacity hard drives connected to their USB inputs. However, some larger capacity drives will require you to use their own power supply, as the player's USB port may not supply enough power for the drive to function.
The primary function of the EDGE NQ is as a network music player. The USB ports are intended for convenient connection of USB thumb drives. As such, we cannot guarantee compatibility with all USB HDD’s.
USB Media Playback (via StreamMagic app)
Connect USB SSD, HDD or flash drive to either to front panel or rear panel USB Input.
Navigate to the Library tab of the StreamMagic app.
3.
Under USB Drives, locate your USB Media device and open it.
4.
Upon selecting a track you will have the option to ‘PLAY FROM HERE’, ‘PLAY TRACK NOW’, ‘PLAY TRACK NEXT’, or ‘QUEUE TRACK’.
USB Playback Options:
PLAY FROM HERE – Playback of the album/folder will begin from this point onwards.
PLAY TRACK NOW– The selected track will playback immediately.
PLAY TRACK NEXT – The selected track will be added to the queue and playback next.
QUEUE TRACK – The selected track will be added to the playback queue
