The EDGE NQ inputs should work with sources with an output as low as approximately 300mV, however the higher the input level, the more responsive the volume control will be.
This is worth considering when using in conjunction with a Phono Preamp as some may have a lower output than 300mV.
We have seen success from customers using our ALVA Duo Moving Coil & Moving Magnet Phono Preamp
