The EDGE NQ has the following built-in streaming services:
- Spotify Connect
- TIDAL
- Qobuz
Note: It is essential that the device you are streaming from (smartphone, tablet, computer, etc.) is on the same Wi-Fi network as the network player to ensure that the units can communicate with each other.
SPOTIFY CONNECT
- Open the Spotify app and choose the playlist, album, song, etc. that you wish to stream to the player.
- Select the devices icon within Spotify and select your Cambridge Audio network player from the list of ‘Listening On’ devices.
- Spotify Connect should now be streaming your chosen content to the player.
TIDAL CONNECT
- Open the TIDAL app and choose the playlist, album, song, etc. that you wish to stream to the player.
- Select the Sound Output devices icon within TIDAL and select your Cambridge Audio network player from the list.
- TIDAL Connect should now be streaming your chosen content to the player.
TIDAL VIA STREAM MAGIC
- Open the StreamMagic app navigate to the Library tab, and then select TIDAL.
Note: Please ensure that you sign into your TIDAL account when prompted to do so. This will only be required on the first instance of use to link the account to the StreamMagic app. - Choose the playlist, album, song, etc. that you wish to stream to the player.
- TIDAL should now be streaming your chosen content to the player.
Note: You may also add TIDAL content to your StreamMagic playing queue by selecting the three elliptical dots next to the content and selecting ‘Add to queue’.
QOBUZ VIA CHROMECAST
- Open the Qobuz app and choose the playlist, album, song, etc. that you wish to stream to the player.
- Select the output devices icon within Qobuz and select the Cambridge Audio network player from the list.
- Qobuz should now be casting your chosen content to the player.
QOBUZ VIA STREAMMAGIC
Open the StreamMagic app navigate to the Library tab, and then select Qobuz.
Note: Please ensure that you sign into your Qobuz account when prompted to do so. This will only be required on the first instance of use to link the account to the StreamMagic app.
- Qobuz should now be streaming your chosen content to the player.
Note: You may also add Qobuz content to your StreamMagic playing queue by selecting the three elliptical dots next to the content and selecting ‘Add to queue’.
