D/A CONVERTER
THD <0.0008%, 20Hz - 20kHz, 24-bit, 1Vrms output
THD ANALOGUE SOURCES
<0.0008%, 20Hz – 20kHz, 1Vrms output
FREQUENCY RESPONSE
20Hz-20kHz +/- 0.1dB
S/N RATIO (REF 1V OUTPUT)
103 dB
CROSSTALK @ 1kHz
< -100 dB
MAX PREAMP OUTPUT
6Vrms single-ended or 6Vrms + 6Vrms balanced
USB AUDIO INPUT
USB Audio Class 2.0 supporting up to 32-bit 384kHz PCM, or up to DSD256
USB DRIVE INPUT
1 x USB 2.0 current limited to 1A, FAT32 / NTFS / HFS / HFS+
BLUETOOTH
4.1 (Smart/BLE enabled) A2DP/AVRCP supporting SBC, AAC, Qualcomm® aptX™ and aptX™ HD audio
TOSLINK INPUT
16/24-bit 32-96kHz
COAX SPDIF INPUT
16/24-bit, 32-192kHz
WI-FI
IEEE 802.11 b/g or n (2.4GHz), Encryption WEP, WPA, WPA2
ETHERNET
MAX POWER CONSUMPTION
100W
STANDBY POWER CONSUMPTION
<0.5W
AUDIO FORMATS
WAV containing uncompressed, PCM 16-24 bit 32-192kHz, FLAC containing losslessly compressed, PCM 16-24 bit 32-192kHz, Apple Lossless (ALAC) containing losslessly compressed PCM 16-24 bit 32-192kHz, AIFF containing uncompressed, PCM 16-24 bit 32-192kHz, Microsoft® Windows Media TM Audio (WMA 9 Standard) 32-320kbps, MP3 (CBR or VBR) 16-320kbps, AAC, HE AAC and AAC+, (CBR or VBR) 16-320kbps, OGG Vorbis 32-320kbps, DSF and DFF containing DSD64 at 2.8224 MHz or DSD128 at 5.6448 MHz.
STREAMING PROTOCOLS
RTSP (Real Time Streaming Protocol), MMS (Microsoft Media Server Protocol), HTTP (Hyper Text Transfer Protocol), HLS (HTTP Live Streaming), DASH (Dynamic Adaptive Streaming over HTTP).
CONNECTIVITY
UPnP, Local USB media, Airplay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL, Qobuz, Amazon Music, Roon Ready.
PLAYLIST
ASX (Microsoft® playlist format) M3U, PLS.
DIMENSIONS
120 x 460 x 405mm (4.7 x 18.1 x 15.9")
WEIGHT
10.2kg (22.4lbs)
