IOS
Important note: Do not plug/unplug the wireless
dongle when the unit is on.
Ensure that your EDGE NQ is in range of your wireless router, and then power on your unit.
On an iOS device go to Wi-Fi settings and under ‘SETUP NEW AIRPLAY SPEAKER’ select 'Edge NQ (ef)’.
3.
Once connected, to complete unit setup download and install the StreamMagic app from the Apple App Store.
ANDROID
Important note: Do not plug/unplug the wireless dongle when the unit is on.
Before attempting to connect your EDGE NQ to your wireless network, download and install the StreamMagic app from the Google Play store.
3.
On an Android device, open the StreamMagic app and on the Home tab select CONNECT.
4.
Under Choose a device select SET UP A NEW DEVICE, and choose Edge NQ as your product to setup.
5.
Under the Set up your Edge NQ, choose WIRELSS CONNECTION and then CONTINUE.
6.
Your Android device will now show all available Wi-Fi devices in range. Select Setup:Edge NQ (eb).
7.
Once connected, you will be prompted to enter your Wi-Fi network password. Enter the password and select CONTINUE.
8.
Your EDGE NQ will now connect to your Wi-Fi network, this may take up to a minute.
9.
Once connected, complete initial setup of your unit within the StreamMagic app.
