DEEZER VIA CHROMECAST
- pen the Deezer app and choose the playlist, album, song, etc. that you wish to stream to your player.
- Select the speaker icon within Deezer, then select 'Google Cast'. Select your player from the list.
- Deezer should now be casting your chosen content to your player.
DEEZER VIA APPLE AIRPLAY
- Open the Deezer app and choose the playlist, album, song, etc. that you wish to stream to your player.
- Select the speaker icon within Deezer, then select ‘AirPlay & Bluetooth’. Select your player from the list.
- Deezer should now be streaming your chosen content to your player via AirPlay.
DEEZER VIA STREAM MAGIC
Note: Please ensure that you sign into your Deezer account when prompted to do so. This will only be required on the first instance of use to link the account to the StreamMagic app.
- Open the StreamMagic app navigate to the ‘Library’ tab, and then select Deezer.
- Choose the playlist, album, song, etc. that you wish to stream to your player.
- Deezer should now be streaming your chosen content to your player.
Note: Your EDGE NQ will need to be running Service Pack version 022-a-131 or later, and your StreamMagic app will need to be running 2.10.0 or later, to stream from Deezer within the StreamMagic app.
BLUETOOTH APTX
Audio can also be played over a Bluetooth connection available by ensuring the included Bluetooth antenna is connected and pairing the Edge NQ to your smart device.
