To enable you to play all tracks from a connected USB hard drive on your Network Player, just follow these three steps.
- Create a folder called 'Music' at the top level (root) of your USB hard drive.
- Move all music on your drive into this new folder.
- Once the USB drive is connected to your player, you will have the option to play all the tracks by navigating to the 'Library' tab in the StreamMagic app > [USB Drive Name] > and pressing play on the Music folder.
