Try these solutions:
- Use different interconnect cables and speaker cables.
- Make sure the unit is not in Standby mode.
- Check that the source component is properly connected.
- Check that your speakers are properly connected.
- Check your source devices’ volume control to ensure this is not muted.
- Check with the alternative source device.
- Ensure that the correct input has been selected via the Balanced/Unbalanced switch.
Â
