Try this solution
Leave the unit for 15 minutes to cool down before pressing the Standby button to resume normal operation
If the unit has not fully cooled down then the temperature may reach the limit soon after the amplifier is powered up.
OVER TEMPERATURE
Over temperature is caused by a combination of high listening levels and low impedance speakers. The Edge W includes temperature detection which constantly monitors the heat generated by the output transistors.
If the monitored temperature reaches a high level (suitably within the limits of the output devices) the amplifier will automatically switch into a fault mode To protect itself from damage.
