If you wish to connect the network Player to one single device, you can use any output, digital or analogue, that you wish.
If however, you would like to connect the Network Player to more than one device at a time, you can connect up to 4 devices and play simultaneously. This is especially beneficial if you are using the Network Player in Digital Preamp Mode or bi-amping.
