There is no sound from one channel on my EDGE A April 12, 2024 09:27 Updated Try this solution Check that the source component is properly connected Check that your speakers are properly connected If possible, use different interconnect cables and speaker cables Check the source component in a different input Related articles There are drop outs in audio when connected to a TV via ARC or Toslink There is weak bass or diffused stereo imaging There is a loud buzz or hum How do I assign radio stations as presets in the StreamMagic app? Only one of my Melomania Touch earphones is working
