To play Spotify content on your 851N, please follow these steps:
- Open your Spotify App and select your desired media.
- Connect to the Network Player using the Spotify 'speaker' icon.
- Spotify should begin playing on your 851N.
If you then wish to save a Spotify playlist, album or 'Artist Radio' as a preset on your 851N, this is also possible. Begin playing your chosen playlist, then using the front panel interface select the Presets menu and select [Set Preset].
Finally, select the preset number you wish to save the playlist as and your Spotify playlist should now be available when you select this preset number.
Please Note - When connecting for the first time both the mobile device and 851N will need to be on the same network in order for the 851N to be discoverable within Spotify.
