If you wish to connect the 851N to one single device, you can use any output, digital or analogue, that you wish.
If however, you would like to connect the 851N to more than one device at a time, you can connect up to 4 devices and play simultaneously. This is especially beneficial if you are using the 851N in Digital Preamp Mode and Bi-Amping.
