IMPORTANT NOTE
It is vitally important that your 851N remains connected to your network as often as possible. This will ensure that the unit is regularly updated to meet essential security protocols, third-party compatibility, and the latest software requirements.
Failure to maintain your device with regular firmware updates as provided by Cambridge Audio will void the product warranty and is likely to cause major issues to the unit in time. Please ensure that your unit is updated to the most current firmware version. Information on the latest firmware version for the 851N can be found here.
Note: The 851N is not compatible with captive portal networks. The 851N works only on 2.4GHz WiFi. Where possible, avoid the use of powerline adapters, or Wi-Fi signal boosters/extenders as these can disrupt the reliability of the network connection.
Note: Do not plug/unplug the wireless dongle when the unit is on.
Ensure that your 851N is in range of your wireless router, and then power on your unit.
On an iOS device, go to your Wi-Fi setting, and under "SETUP NEW AIRPLAY SPEAKER" select '851N'. Alternatively (or if using an Android), when prompted on the front panel display connect to the Wi-Fi network of your choice. Select your Wi-Fi network from the list and then enter your password.
Note: Wi-Fi network passwords are case-sensitive.
3.
to complete unit setup download and install the StreamMagic app either from the Apple App Store or Google Play Store.
