If you are experiencing issues with the functionality of the 851N, we would initially recommend disconnecting the unit from power before reconnecting.
There are three ways to factory reset the 851N:
- The first option is to simply select 'Factory Reset' in the 851N Settings menu.
- The second option is to power on the device from Standby with the select knob pressed in. Keep the knob pressed in until 'Factory Reset' appears on the screen.
- The third option is to to perform a 'Factory Reset' via Settings within the StreamMagic app.
