What Size Banana Plugs are compatible? April 02, 2024 13:03 Our products are compatible with standard 4mm banana plugs. Related articles Can I connect banana plugs to the AXA25? How do I use banana plugs? How do I use banana plugs? How to fit banana plugs/tips What is the difference between using 3.5mm or RCA input?
