Power output - 25 Watts (into 8Ω)
THD (unweighted) - <0.015% @ 1kHz, 80% of rated power <0.15% 20Hz – 20kHz, 80% of rated power <0.1% 20Hz – 20kHz @ 10W
Frequency response - (-3dB) 10Hz - 30kHz
S/N ratio - (ref 1W) >82dB (unweighted)
Input impedances - 32k Ohms
Power Amp damping factor - > 100
Max. power consumption - 180W
Bass/Treble controls - Shelving, ultimate boost/cut +/- 5.5dB @ 20Hz and 20kHz
Standby power consumption - <0.5W
Inputs: - 4x RCA, 1 x 3.5mm Aux input (front panel)
Outputs: - Speakers, Rec Out, USB 5V power
Dimensions (HxWxD): - 83 x 430 x 340mm (3.3 x 16.9 x 13.4”)
Weight: - 5.1kg (11.2lbs)
