Summary:
FIP Radio stations (France) are currently not working on the following Cambridge Audio products:
- NP30
- StreamMagic 6
- Minx Xi
Update (26th Feb 2021):
Our engineers have confirmed that something has changed in the stream provided by FIP that causes issues with the playback engine in certain products.
This, unfortunately, means that these new FIP streams are no longer compatible with our legacy streaming products; NP30, Stream Magic 6 v1, Minx Xi.
Regrettably, this is not an issue that can be resolved with a firmware update as previously thought, due to the fact that the new stream format that FIP is now using is not compatible with the chipset used in these products.
We do sincerely apologies for any inconvenience or disappointment that this may cause. If you have any further questions please contact support via the form below.
