There is no sound on one channel March 25, 2024 15:32 Updated Try this solution: Check speaker connections and interconnects. Check that the Alva Duo balance control is set centrally. Related articles Volume is too loud/quiet No sound through one or both channels There is a loud buzz or hum Will my A100 remember settings I changed using a different device? Azur 840C User Manual & IR Codes
