Some phone models need an additional step:
In your phone's Bluetooth settings:
1. Find your headphones in the connected devices list
2. Tap the settings icon next to the device name
3. Look for the LDAC toggle and switch it on
The app will then display LDAC in the codec section (above your device title).
If there's no LDAC option: You'll need to enable Developer Options first:
1. Go to Settings > About Phone
2. Tap Build Number seven times until a message confirms it’s enabled
3. Find Developer Options (usually under System or Additional Settings)
4. Look for Bluetooth audio codec settings and select LDAC
Note: Multipoint remains disabled while LDAC is active.
